Zoznam nepredaných rádioamatérskych zariadení z pozostalosti po OM4AWM
OM1ALF
Dátum registrácie: Pi Dec 30, 2016 4:30 pm
Príspevok od používateľa OM1ALF »
Transceiver Kenwood TS-990 ...................................................4.000,- EUR
External Speaker SP-990 .............................................................250,- EUR
Mikrofón Kenwood MC-90............................................................ 250,- EUR
Transceiver ICOM IC - 7100 .........................................................890,- EUR
Transceiver ICOM IC - 7400 + mikrofón ICOM HM-219.............. 550,- EUR
Transceiver VHF - Kenwood TS-700SP ......................................200,- EUR
Transceiver QRP TEN-TEC R4020 2 band 20/40 m...... .............200,- EUR
ICOM IC-R 20 Japan - skener /komunikačný prijímáč.................650,- EUR
Kenwood FM Dual Bander TH-F7 Handradio ..............................150,- EUR
CMX-2300 Twin cross SWR / Power meter.................................. 280,- EUR
NISSEI TX1202 SWR/Watmeter................................................... 199,- EUR
MFJ-844 Dual Band SWR/WATT Meter 15W 60W 220W ............. 60,- EUR
MFJ-267 Dummy Load Wattmeter .............................................. 200,- EUR
BM344 Tesla RC Generátor .......................................................... 25,- EUR
Ameritron AL-811H - Power Amplifier HF Koncový stupeň...........550,- EUR
MX-P50A Koncový stupeň............................................................130,- EUR
CB Master: CB-50 koncový stupeň................................................ 50,- EUR
CB Master -150 koncový stupeň................................................... 50,- EUR
CB Master EA-150P koncový stupeň............................................ 50,- EUR
FlatPack 2 2000W Zdroj.................................................................50,- EUR
SP-8 YAESU External SPEAKER................................................. 150,- EUR
SM-20 ICOM Mikrofón................................................................. 170,- EUR
LDG Electronics Z-100 Automatic Tuner..................................... 160,- EUR
LDG Electronics AT-100 Pro II Automatic Tuner.......................... 290,- EUR
YAESU FC-40 Automatic tuner pre FT-897/857 ........................ 150.- EUR
ACS-2004 SBS Antenna selector Anténny prepínač ....................300,- EUR
MFJ 1700C Anténny prepínač..................................................... 120,- EUR
DCM-2: 144-148MHZ->28-32MHZ Converter ............................. 50,- EUR
TOKYO HY-POWER HX-240 2m->HF "reverse" transverter........ 200,- EUR
MFJ-1128 12-zásuvka na 12V až pre 12 zariadení. .....................120,- EUR
ICOM AH-4 HF + 50MHz Automatic anténa Tuner (nový)............380,- EUR
CrankIR portable StepIR Antenna ...............................................310,- EUR
MFJ VERSA Tuner III MFJ-962D ................................................ 120,- EUR
HVA-200 Mini AV Digital Surround Amplifier ............................... 25,- EUR
Telekom anténa BM-160-PL BASE MAGNETICA 16cm.................40,- EUR
YEASU ANTENNA CONTROLLER G-250 ................................... 35,- EUR
CB rádiostanice:
President TAYLOR III .................................................................... 120,- EUR
Conrad C-Mobil G013 ELECTRONIC 498A - 40 kanálový............. 30,- EUR
Onwa 2-6112-11 ............................................................................. 40,- EUR
TEAM TS404FM ............................................................................. 80,- EUR
Záujemcov o uvedené zariadenia chcem požiadať aby svoje ponuky a návrhy smerovali ma pani Molnárovú č.t.: 0905 459 238
OM1ALF
Re: Zoznam nepredaných rádioamatérskych zariadení z pozostalosti po OM4AWM
BM344 Tesla RC Generátor a President TAYLOR III REZERVOVANÉ do 6.10.2023
OM1ALF
CrankIR portable StepIR Antenna REZERVOVANÁ do 6.10.2023
OM1ALF
MFJ VERSA Tuner III MFJ-962D - PREDANÝ
OM1ALF
YEASU ANTENNA CONTROLLER G-250 - REZERVOVANÉ do 1.10.2023
OM1ALF
Ameritron AL-811H - Power Amplifier HF Koncový stupeň - REZERVOVANÝ do 2.10-2023
OM1ALF
Transceiver ICOM IC - 7400 + mikrofón ICOM HM-219 - PREDANÉ
OM1ALF
YEASU ANTENNA CONTROLLER G-250 spolu s rotátorom a anténou - PREDANÉ
OM1ALF
BM344 Tesla RC Generátor a President TAYLOR III - PREDANÉ
Ameritron AL-811H - Power Amplifier HF Koncový stupeň - PREDANÝ
Kenwood FM Dual Bander TH-F7 - PREDANÁ
MX-P50A Koncový stupeň - PREDANÝ
OM1ALF
Transceiver ICOM IC - 7100 - REZERVOVANÝ do 3.10.2023
OM1ALF
Transceiver ICOM IC - 7100 - PREDANÝ
OM1ALF
Špeciálna ponuka:
Montovaný 3 dielny anténny stožiar Pre vertikálnu HF anténu spolu s anténou. Pre obhliadku - prípadne cenový návrh volajte
pani Molnárovú t.č. ‭0905 459 238‬. Stožiar sa nachádza v Drietomej pri Trenčíne.
Stožiar s HF vertikálnou anténou.png (220.44 KiB) 4319 zobrazení
OM1ALF
Špecifikácia antény na Stožiari: AV-18HT - Hy-Tower Vertical Anténa 10, 15, 20, 40 and 80 Meters hy - gain
OM1ALF
Ešte prikladáme detail ukotvenia anténneho stožiara:
Ukotvenie anténneho stožiara.png (1.95 MiB) 4307 zobrazení
OM1ALF
LDG Electronics AT-100 Pro II Automatic Tuner.........................PREDANÝ
Užívatelia prezerajúci toto fórum: Bing [Bot] a 2 neregistrovaní
