Transceiver Kenwood TS-990
External Speaker SP-990
Mikrofón Kenwood MC-90........................................................3990,- EUR
Transceiver VHF - Kenwood TS-700SP ........................................200,- EUR
Transceiver QRP TEN-TEC R4020 2 band 20/40 m...... ................200,- EUR
ICOM IC-R 20 Japan - skener /komunikačný prijímáč.................850,- EUR
CMX-2300 Twin cross SWR / Power meter.................................. 280,- EUR
NISSEI TX1202 SWR/Watmeter................................................... 199,- EUR
MFJ-844 Dual Band SWR/WATT Meter 15W 60W 220W ............. 60,- EUR
MFJ-267 Dummy Load Wattmeter .............................................. 200,- EUR
CB Master: CB-50 koncový stupeň................................................ 50,- EUR
CB Master -150 koncový stupeň................................................... 50,- EUR
CB Master EA-150P koncový stupeň............................................ 50,- EUR
FlatPack 2 2000W Zdroj.................................................................50,- EUR
SP-8 YAESU External SPEAKER.................................................... 150,- EUR
ICOM AH-4 HF + 50MHz Automatic anténa Tuner (nový)...........380,- EUR
LDG Electronics Z-100 Automatic Tuner..................................... 160,- EUR
YAESU FC-40 Automatic tuner pre FT-897/857 ........................ 150.- EUR
ACS-2004 SBS Antenna selector Anténny prepínač ....................300,- EUR
MFJ 1700C Anténny prepínač..................................................... 120,- EUR
DCM-2: 144-148MHZ->28-32MHZ Converter ............................. 50,- EUR
TOKYO HY-POWER HX-240 2m->HF "reverse" transverter.......... 200,- EUR
MFJ-1128 12-zásuvka na 12V až pre 12 zariadení. .....................120,- EUR
HVA-200 Mini AV Digital Surround Amplifier ............................... 25,- EUR
Telekom anténa BM-160-PL BASE MAGNETICA 16cm..................40,- EUR
CB rádiostanice:
Conrad C-Mobil G013 ELECTRONIC 498A - 40 kanálový............. 30,- EUR
Onwa 2-6112-11 .......................................................................... 40,- EUR
TEAM TS404FM ........................................................................... 80,- EUR
Aktuálny zoznam nepredaných rádioamatérskych zariadení z pozostalosti po OM4AWM
OM1ALF
- Dátum registrácie: Pi Dec 30, 2016 4:30 pm
OM1ALF
Re: Aktuálny zoznam nepredaných rádioamatérskych zariadení z pozostalosti po OM4AWM
Záujemcovia o kúpu zariadení volajte pani Molnárovú t.č. 0905 459 238
OM1ALF
DCM-2: 144-148MHZ->28-32MHZ Converter - PREDANÝ
